Roborock App - Tap. Tap. Clean. | Roborock ロボロック公式サイト
Tap. Tap. Clean.
ビデオを再生
Simply tap your phone and let your robot vacuum get to work as you wish, enjoying a worry-free cleaning experience with Roborock App.
5 Reasons to try Roborock App
Customize Multi-Purpose Cleaning
Enhance Cleaning Effectiveness
Map Your Home Precisely
Avoid Obstacles and Risky Areas
Check Robot Status Anytime
Clean As You Wish
Customize Every Cleaning Task
Tap Where to Clean
Clean As You Wish
Tap Where to Clean
Full House
Specific Rooms
Specific Zones
Specific Spot
Tap How to Clean
Vac&Mop
Vacuum-Only
Mop-Only
Customize
Tap How to Clean
Vac&Mop
Vacuum-Only
Mop-Only
Customize
Schedule Daily Cleaning Routines
Create a routine for daily uses i.e. cleaning the dining area after meals. Pick a time, cleaning mode, and the rooms you need, and it will repeat automatically.
Level Up Cleaning Experience
For Carpets
Activate carpet boost and deep mode to clean carpets twice in one task for better cleaning performance.
For Hardwood Floors
Let the robot vacuum clean the floor along its direction so the floor seams can be cleaned all along and minimize scraping against them.
Smart and Worry-free
The Best Route, Everytime
Scans quickly to know your home environment and creates detailed maps to find an optimal route to clean your home, leaving dirt with no escape.
6x Faster
Quick Mapping1
On its first run, the robot vacuum will quickly create a detailed map, so you can start cleaning ASAP.
2D, 3D & Matrix
Map Displays
Multiple map displays allow you to navigate your house with more fun.
Multi-level
Mapping System2
The robot vacuum automatically recognizes distinct levels of your home. All you have to do is put the robot down.
Manage Your Virtual Home
Easily control where the robot vacuum goes by editing room layouts, No-Go Zones, and cleaning sequences in your map.
Smart Enough to Stay Out of Troubles
For Obstacles
Detects and avoids objects on the floor easily, so you don't have to worry about picking up them from the floor before it starts cleaning.
For Risky Areas
Suggests No-Go Zones automatically, to prevent your robot vacuum getting stuck in tight spots, or falling down the stairs accidentally.
Design What You Care
Off-Peak Charging Supported
Set up off-peak times to charge your robot vacuum and save money on your electricity bill.
Check Accessory Status Anytime
Easily check the usage status of your robot vacuum's accessories, so you know when it's time to maintain or replace them.
Explore More with Remote Control
Drive your robot vacuum directly to any spot in your home, so you can explore more uses beyond cleaning.
Remote Control
Spot Clean
Video Calling
Complete Control at Your Fingertips
Download Roborock App and enjoy a worry-free cleaning experience at your fingertips.
Endnotes:
*Some features may not be available on all Roborock products.
1. Compared to Clean&Mapping mode. Actual results may vary according to the home environment.
2. Up to four floors supported.
